radiator spewing fluid.
Old Dec 16, 2008 | 09:04 PM
jadmt's Avatar
jadmt
Now that it dropped down in to minus double digits my radiator started leaking at the top seam (side opposite the cap). I called the radiator shop and they said it is common with older fords. They said the gasket shrinks. They said it is an easy fix to replace the gaskets and recrimp. ~$200 including radiator removal and install. He said as soon as it gets frigid he sees a lot of fords.
Old Dec 16, 2008 | 11:52 PM
Old93junk's Avatar
Old93junk
This re crimping job works well, did it several years ago, no leaks since. Hellva lot cheaper than a new radiator!
Old Dec 17, 2008 | 05:47 AM
fmr9's Avatar
fmr9
You need a new radiator and a new radiator shop.
Couple years ago mine was leaking and an honest shop told me it would cost more to fix than buy a new one. Plus even if fixed the old one would have many years worth of crud stuck in the tubes, and many potential leaks waiting their turn to appear. Got a new one from Advance Auto after price match to Rock Auto. Was around $140. Not a hard job to replace, and a good time to replace radiator cap, hoses, thermostat, and maybe heater core if it is original. Use a good flush before changing parts and you are good to go for a long time. Less than 4 hours work to do all of it.
Good Luck Frank
Old Dec 17, 2008 | 07:01 AM
jadmt's Avatar
jadmt
Good Luck Frank
My raditator is solid other than the gaskets. It only has 33,000 miles and the shop advises up front they will not repair the radiator if it is not solid to begin with. 4 hours in minus 15 is not worth saving $200 to me. If it was nice out that would be a different story. For my application ie hd super cooling it is over $200 at rock auto plus shipping.
Old Dec 17, 2008 | 08:24 AM
fmr9's Avatar
fmr9
Yes you are right. Working on this outside in minus 15 weather is not a good option at nearly any price. The radiator I replaced had over 150,000 miles and at least one dose of stop leak.
Good Luck Frank
Old Dec 17, 2008 | 07:04 PM
jadmt's Avatar
jadmt
Picked it up and good as new. He said it was in perfect shape and that it was very clean when they rodded it out. If it lasts another 20 years I will be happy LOL>
PSDx3
6.4L Power Stroke Diesel
Jan 29, 2022 03:45 PM
tom from mass
Apr 4, 2014 03:38 PM
lemonshindig
Dec 4, 2013 09:13 PM
airsurf
Feb 11, 2010 07:00 PM
b4000er
1983 - 2012 Ranger & B-Series
17
Mar 3, 2005 02:06 AM
