Dewatering question
Old 12-10-2008, 05:54 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Dewatering question
We finally have 220 running out to the shed for out GL Eco-Processor. According to Lamling, he recommends heating the oil to 90c to dewater. The 50 gallon Water heater that we use only goes up to 66c or 150f. You would think that even @ 150, there would be water steaming off, especially since we are 3200 above sea level. most of our water should have seperated out in the settling tank anyway.? The question that we have is, do we run the pump when the oil is heated up, or just maintain the heat @ 150 in the tank. thanks
Old 12-10-2008, 07:24 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
I heat the oil to about 160*F in a open drum with a air fitting and valve on the bottom and a small fan blowing across the top. once the oil is heated to the 160 I put about 20 psi of air through it, you can see the water vapor blowing off the top like a fog. once the fog clears you're basicly water free.this process normaly takes about an hour for relativly "wet" oil
Old 12-10-2008, 08:17 PM
empiretc's Avatar
empiretc
empiretc is offline
i heat the oil a lot hotter than that. Water boils at 212* F.
Old 12-10-2008, 08:39 PM
MAKO314's Avatar
MAKO314
MAKO314 is offline
In the summer months when the air here in humid as the congo I'll heat the oil to 212 or so but in the fall and winter when the air is dry and cool 160 or so causes the water to heat off without boiling and it takes less energy.the air bubbleing through the oil also causes the free water to fall out and the desolved water to escape out in the air bubbles.
Old 12-10-2008, 09:57 PM
Rushmore X's Avatar
Rushmore X
So then the air being pulled through the venturi helps to dry the oil... In other words I need to run the pump during the process. thanks, we were just wanting to make sure...
thanks again
Old 12-16-2008, 05:20 PM
spam0012's Avatar
spam0012
spam0012 is offline
Heck I just heat it up with a sumbersible heater in an open drum. I have a pump that I use to then circulate the heat fuel and spray it across the sides of the drum. Once it gets really warm 100-120 F then I let it go until it clears up and then and aditional 15-20 minutes. I never had a problem.
Old 12-16-2008, 07:35 PM
Rushmore X's Avatar
Rushmore X
Were did you find a submersible heater? Most of the heaters that I have seen are meant for keeping stock tanks open for cattle and float on the surface.
Old 12-17-2008, 05:51 PM
zhilton's Avatar
zhilton
zhilton is offline
Here are a couple of choices after a quick search on Google:
Submersible Water Heater - Home & Garden - Compare Prices, Reviews and Buy at NexTag - Price - Review
Old 12-17-2008, 06:04 PM
Rushmore X's Avatar
Rushmore X
thanks, looks like we need at least a thousand watt to heat about 50 gallons of oil enough so it flows.
Old 12-17-2008, 07:02 PM
zhilton's Avatar
zhilton
zhilton is offline
True, if you in a hurry...or it's really cold where your filtering oil you may need a 1000 watts. I wonder since most of those have thermostats in them...could you "dial 'em up" if they're not getting the oil warm enough to flow? A couple of them said they're plastic safe...so it sounds like you could use 'em in one of those 250-300 gallon plastic shipping totes.
Old 12-18-2008, 05:36 AM
sundy58's Avatar
sundy58
sundy58 is offline
submersible heater
I am a home brewer and have made a couple of 220vac portable water heaters from hot water heater elements. I will post the links to instructions later today. It real easy just find low density water heater elements, use a sink tailstock for a handle. Wire it up and you have a 4500 watt heater for $50 or less. McMaster sells submersible heaters but they are a heck of alot more.
Old 12-18-2008, 06:02 PM
Rushmore X's Avatar
Rushmore X
look forward to seeing it. Already unusually colder than normal here, and we have frozen oil to deal with now.
Old 12-19-2008, 06:43 AM
sundy58's Avatar
sundy58
sundy58 is offline
alfter.us - Heatstick Construction
Burners & Electric Pot Heaters - High Gravity
Here are two examples but I can't find the best one. These won't work with solid oil. You must have liquid around the element.
McMaster has drum heaters that wrap around a drum but they aren't cheap. One of those might give you liquid to work with.
Find Sandhog Long Life II Heating Element, 4500W x 240V and other Water Heaters at Aubuchon Hardware this is the heater element I bought.
Old 12-19-2008, 06:48 AM
sundy58's Avatar
sundy58
sundy58 is offline
Old 12-19-2008, 06:51 AM
sundy58's Avatar
sundy58
sundy58 is offline
This one shows putting the element in the barrel. We use 1/2 barrels (16 gallon keg) for brewing. I would think a bigger barrel would be even easier.
CD's New Electric Wort Boiler
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
21
03-09-2009 09:10 AM
Rushmore X
01-18-2009 10:27 PM
MAKO314
07-17-2008 06:13 AM
TchTchr
03-24-2008 03:13 PM
fabmandelux
08-14-2006 04:58 AM
Quick Reply: Dewatering question
