FYI if you don't already know you are not suppose to drive in 4x4 on dry pavement. Thats seems to be when you get the most noise from the front end when you make hard turns.
I get some more noise with the hubs in and the Tcase in 2wd. Usually try to stay under 60 w/the hubs in but have ran older trucks faster. 4x4 ingaged under 45, but as mentioned the conditions should be slick enuf to need 4x4.
i race at the strip with my hubs locked in (obviously) and i trapped 93.81... it didn't make any noise and no vibrations till i let off... but i do have 33" mud tires and they did still vibrated in 2wd trapping 93.84
why do u you ask? hwy speed ? if you would ever drop the pin in the front end at hwy speed you would never do it again frot wheels lock up and you cant steer i know first hand happend years back to my 79 not fun. but i still do it evey time it snows as i have a plow hanging on the front. now if your truck is rumbling and all u-joints are good you need to ajust your air in the tires do not go over the psi on the tire , but air up according to what is on the door post the front is never the same as the back and is on most all cars and trucks and yes it madders 2 wheel or 4 wheel
I thought starting out in 4HI and shifting back after about 100 feet or so was the norm for the strip. You leave it in 4HI the whole time?
there is no limit for what you can run in 4 HI. Its a drive line, and designed for heavy torque, amplified when in LOW. Shifting from 2 to 4 should never be done while rear end is slipping, and should ideally be done under 45 mph.
FYI, years ago, Lamborghini made a truck that was stock and clocked WELL over 120 mph in 4wd, looked like a modern day smaller version of a hummer.
It's no different (the shifting part) than using any old straight-cut-geared tranny. You just have to match RPMs and be gentle. Even shifting from 4 low to high, or the other way around. Be VERY careful, and definitely not under power for the lo-high shift.
If you have manual hubs and they are locked in, it should be safe to shift in or out of 4WD at any speed. With auto hubs I would be stopped when shifting into or out of 4WD. Spinning your front axle up to speed from a dead stop in an instant is not good for the hubs when they engage, or the ujoints on the axle and driveshaft, or tcase front output I would suspect.
