ford 302 problem
Old Dec 16, 2008 | 04:25 PM
deereman2's Avatar
deereman2
ford 302 problem
My 302 idles great, and does great when I really hit it, but at mid throttle it runs rough. I have to let off the gas so there is no load on it or give it more gas so that there is a real load on it to get it to run right. I've rebuilt the carburetor, and replaced the fuel filter, points, condensor, distributor cap, plugs, plug wires, coil. The fuel pump is good.
This problem just popped up all of a sudden, one day I was driving it and everything was fine, the next it had this problem.
Does anyone have any ideas?
Old Dec 16, 2008 | 04:37 PM
Customcab's Avatar
Customcab
I could be way off; but motor mounts have cause this reaction in the past for me and a buddy of mine one time. Also at high end seem fuel pumps to lose their capacity to push fuel.
But i'm sure its something else. Just trying to get ya to check your motor mounts.
Mitch
Old Dec 16, 2008 | 05:00 PM
Beechkid's Avatar
Beechkid
I would check 2 items,
1. Fuel pressure while driving at the speed it occurs- possible fuel pump
2. A small particle might have found it's way into the carb fuel passages
3. Power valve/accelorator pump might not be adjusted right or have a pinhole in the diaphram
Old Dec 16, 2008 | 06:28 PM
slo5.0's Avatar
slo5.0
Did you replace the power valve when you rebuilt the carb? If so, was it an exact duplicate? Did it happen right after rebuilt? If its a Holley carb, the power valve is known to blow out very easily with a simple back fire. There is a "power valve protection kit" offered from Holley or Summit. Hope this helps!!
west coast chopper
Feb 10, 2014 10:01 AM
ocoee
Nov 25, 2008 07:05 PM
e150mtroy
Apr 9, 2006 03:40 PM
ObiWanJak
Mar 31, 2003 09:52 PM
fyreline
Dec 25, 2000 11:44 PM
