Stock Tire Size
Old Dec 16, 2008 | 01:03 PM
aocabrown's Avatar
aocabrown
Stock Tire Size
In the market for new tires. I believe mine has 265/70-16's on the original/stock wheels. Tire store says the 'stock' tire is a 235/85-16.
I'm trying to find out what my various brand/tread/price options are..but I need to narrow the size down first. I was hoping to go slighly larger than what I currently have but I'm confused since what I have seems to be quite a bit larger than the 'original' size.
Thoughts/comments.
Old Dec 16, 2008 | 01:09 PM
big poppa's Avatar
big poppa
On my 250 the stock tires were 265-75-r16 E rated. I,m running 285-75-16 D rated now. You can go bigger, more people will help you out shortly that run bigger tires.
Old Dec 16, 2008 | 01:23 PM
250turbo's Avatar
250turbo
check door jam sticker.
kurt
Old Dec 16, 2008 | 01:29 PM
guitarpicr's Avatar
guitarpicr
Mines an 2002 & and stock size is 265-75R16- Load range E -Hard to find a 285 Load range E -I know Michelin makes one in the but its pretty pricey.
Old Jun 25, 2023 | 10:10 PM
WyoBoy78's Avatar
WyoBoy78
2nd Gear
I checked the door jam tag and it didn't have tire size unfortunately
Old Jun 26, 2023 | 12:28 AM
John in OkieLand's Avatar
John in OkieLand
look up the VIN,
that usually shows every thing the truck came with.
this is for my truck, insert your VIN under TECH SPECS
https://www.ford-trucks.com/forums/v...SU41F92EA32633
Front Tire Size LT265/75R16D
Rear Tire Size LT265/75R16D
Spare Tire Size LT265/75R16D
kitz
Mar 12, 2023 12:21 PM
KC8QVO
Nov 7, 2010 06:06 PM
brianas
Dec 23, 2006 01:34 PM
MEPR
Jan 21, 2003 09:11 PM
