Sponsored by: Kumho
3/4 or 1 ton?
Old Jun 3, 2001 | 07:51 PM
bpowell's Avatar
bpowell
3/4 or 1 ton?
Old Sep 5, 2001 | 07:04 AM
poore1's Avatar
poore1
3/4 or 1 ton?
I bought a used 1988 ford f250 diesel. The last owner said it came from the factory with a 1 ton suspension. How do I tell if it is a 3/4 ton or 1 ton?
Thanks
Old Sep 5, 2001 | 04:03 PM
DeGideo's Avatar
DeGideo
3/4 or 1 ton?
The 1 ton pickups came with a Dana 60 straight axle,up front. The 3/4 ton pickups had a Dana 50 and TTB(twin traction beam) front suspension. The 3/4 tons had a snowplowing front suspension package with a host of stiffer pieces,but I'm unsure what was actually included.It could also be your F-250 had a F-350's Dana 60 axle swapped in place of the 50-series.Both trucks used a Ford 10 1/4" rear axle,but diesel-powered trucks got higher rate capacity rear springs than models that had gasoline engines.Hope this helps.
Old Sep 7, 2001 | 08:33 PM
jkiser96's Avatar
jkiser96
3/4 or 1 ton?
I have seen 1-ton trucks that had the IFS under it but it ws a Dana 60 IFS. The best way to find out for sure is to check the VIN # & that should give you all the info you need on the truck.
Old Sep 7, 2001 | 09:28 PM
slimersoup's Avatar
slimersoup
3/4 or 1 ton?
Some F250's have an extra leaf spring pack mounted about 4 inches above the regular pack. Neither end of the spring has a solid mount to the chassis; there are some rubber bumpstops that they will hit after the suspension compresses a couple inches. This is the same setup that F350's have. For some oddball reason the extra spring and the bumstops were removed from my truck before I got it, I have no idea why unless they stole it for another F250.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
