Holley 390 adjustment
Old Dec 16, 2008 | 10:54 AM
lordoflivernois's Avatar
lordoflivernois
I have a 79 F100 300, with a holley 390 4bbl., it idles really high, and no matter how far I turn the idle adjustment screw back it stays high.. in the manual for the 390 it show a high idle adjustment screw that works in conjunction with the choke. For some reason i dont see it on my carb.. and help would be great ... thanks..
Old Dec 16, 2008 | 01:36 PM
Harte3's Avatar
Harte3
IIRC, when facing the choke housing, the adjustment screw will be behind the left side of the housing with the screw head pointed down. Also, check for vacuum leaks and linkage clearances before moving that screw. And, if the choke is set with the pointer straight up, move it 2-3 marks to the right before adjusting the screw and see how that works. Seems to be a Holley thing...with several I have had I found that seems to be where choke operation is the best or at least provides a good starting point.
Old Dec 16, 2008 | 02:15 PM
lordoflivernois
thank you..
1982fordf100
Sep 5, 2006 09:20 PM
MRStace84
Mar 4, 2005 03:31 PM
MRStace84
Nov 11, 2003 09:22 AM
gadams
Mar 13, 2001 02:10 AM
