Y-pipe
Old Dec 15, 2008 | 03:28 PM
rootbeerford's Avatar
rootbeerford
Y-pipe
So I want to put an exhaust system on my truck. The only Y-pipe I have seen for it is a bassani, which is pricey enough for the off road version. What are some other Y-pipes out there?
Old Dec 19, 2008 | 09:36 PM
stillneedswork's Avatar
stillneedswork
i know flowmaster makes one and you can get a cheap one from your local parts store
Old Dec 21, 2008 | 12:00 AM
-Mike-'s Avatar
-Mike-
They are easy to make too if you have a welder, flanges and some U-bends.
Old Dec 21, 2008 | 10:08 AM
TexasGuy001's Avatar
TexasGuy001
I think Catco makes one. I know that Magnaflow does. A friend of mine has a Magnaflow Y-pipe with cats and it was only a couple hundred bucks.
Old Dec 21, 2008 | 10:36 AM
stillneedswork
lmc truck sells them too
Old Dec 21, 2008 | 01:17 PM
rmiller01's Avatar
rmiller01
Jegs has them also around $200
Old Mar 8, 2009 | 09:19 PM
nerraw117's Avatar
nerraw117
will this one work MagnaFlow 10778 - MagnaFlow Stamped Y-Pipes - summitracing.com I saw it on another post.
Old Mar 9, 2009 | 09:03 PM
gbrewer's Avatar
gbrewer
welded one
welded in one, looks good and functions better
Old Mar 9, 2009 | 09:39 PM
nerraw117's Avatar
nerraw117
couldnt i cut off before the flang and weld this y-pipe on?
