NO Heat
Old Dec 15, 2008 | 02:18 PM
02X72's Avatar
02X72
NO Heat
Today, the heat in my 2002 Excursion(7.3) stopped working. It may be a coincidence, but last night and today are by far the coldest days of the year with a -25 windchill. It will blow air out with plenty of force, but its ice cold. The thermostat is opening, since the hoses are hot after driving it. The guage is also reading that the truck is warming up. Where should i start?
Old Dec 15, 2008 | 06:27 PM
tbear's Avatar
tbear
Since your truck is hot/warm and the blower is working, I would check the heater hose at the firewall to make sure coolant is getting to the heater core. That line could contain frozen antifreeze.
You could also check/feel the temperature guage for the heater on the dash (does it feel loose) it could have broken free of it's retaining clip ( I had an old Ford, yours might be less mechanical) and is "stuck" on cool/not adjusting the temp.
Possibly last would be a clogged heater core. Doubtful in a 2002.
After that, I'm stuck. The experts on here will have to help you.
Good luck, Ted
Old Dec 16, 2008 | 01:55 PM
02X72's Avatar
02X72
Thanks for the reply. It started working this morning, so I will probably never know what it was. I think it was the heater hose being frozen and driving it around melted it enough to blow it out though. Only thing that would of made sense.
Old Dec 18, 2008 | 08:20 AM
projectSHO89's Avatar
projectSHO89
Have you checked the concentration of the antifreeze to be sure you have adequate freeze protection? It does sound like the lines to the core were frozen and the heat from the engine eventually melted the ice.
Please not that windchill is irrelevant, the actual temperature is what is important in this case.
Steve
abe
Oct 12, 2012 12:05 PM
Hunter40
Feb 28, 2007 05:14 PM
ckeezer
1978 - 1996 Big Bronco
Dec 27, 2006 07:46 PM
150ford
Nebraska Chapter
Jul 22, 2006 04:02 PM
cact34r
Feb 8, 2002 11:36 PM
