Modular V10 (6.8l)
Wrong oil to use?
Old Dec 18, 2008 | 06:10 PM
dkf's Avatar
dkf
Yep let her run. The rev limiter won't let you over rev the engine. (Set around 5400rpm in drive)
Old Dec 26, 2008 | 06:32 PM
flybaby_3's Avatar
flybaby_3
We have about 20 F150's and F250's at the plant here (60 miles north of Detroit) and while the trucks are under warranty we use 5W20 then switch to 5W30 after the warranty expires. We have new 09's down to 03's V8 equipped but no V10's. Believe me, they are abused. You know, drive it like you stole it. The guy who is in charge of maintenance is quite **** about keeping records. According to him mileage is no different after the switch and we have not had any oil related engine problems either. Personally, I still run the 5W20, but only because I can buy it as cheap as the 5W30, other wise I'd switch.
Old Dec 27, 2008 | 09:06 AM
WJC's Avatar
WJC
i noticed my last oil change my mechanic put 5w-30 in my 05 excursion and it calls for 5w-20, i did see a slight drop in mileage, however, i thought it was due to the cooler weather and winter blend fuel. however, i will be switching back to factory spec oil weight during the next change.
Old Dec 27, 2008 | 02:25 PM
mikehm's Avatar
mikehm
I believe Fords change from 5W-30 to 5W20 was only for better mileage, but you dont want to go with any oil heaver than 5W-30. When I first got my used V-10 at 70K, it had 15W-40 in it, and upon start up the cam chains would take too long to get oiled to suit me, so I switched back to 5W-20 or 30, and the problem went away. I cant really tell the difference between the two, and I only use Mobil 1, but that's just me.
o2compressor
Escape & Escape Hybrid
May 15, 2010 09:53 PM
BoDuke26
Oil & Lubrication
19
Feb 2, 2006 06:23 AM
Flash
Oil & Lubrication
44
Sep 1, 2005 04:11 AM
mrxlh
May 28, 2004 06:35 PM
brg_ranger
Oil & Lubrication
Apr 23, 2003 03:57 AM
