fuel filter drain plug
Old Dec 15, 2008 | 11:55 AM
zavierbr's Avatar
zavierbr
Unhappy fuel filter drain plug
Change my fuel filter out yesterday and notice that the drain tube is drippeing fuel slowly. What should I do to correct this problem? I really don't want to of to take it to the dealer.
Old Dec 15, 2008 | 11:58 AM
superduty4x4's Avatar
superduty4x4
No need to take it to the dealer, all you need are two 1/2" OD, 1/4" ID, 1/8" wall O-rings. Viton are best, buna-n or nitrile will work just fine. You should be able to get them at a good parts or hardware store, I bought an 8 pack at Schucks for around $3. Then you pull the drain valve off the fuel bowl (#25 Torx bit IIRC) and replace the o-rings, easy sleasy. Takes about 10 minutes to do.
Ponyboychris's Avatar
Ponyboychris
Here's a repair write-up:
Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
Old Dec 15, 2008 | 12:15 PM
zavierbr's Avatar
zavierbr
thank you, I will try this before taking it to the dealer.
Old Dec 15, 2008 | 01:24 PM
SpringerPop's Avatar
SpringerPop
If you follow the directions, you won't be taking it to the dealer at all.
Pop
Old Dec 15, 2008 | 01:31 PM
Ponyboychris
Yes, it's pretty simple fix. Just don't drop the screws into the engine valley or over-tighten the screws when you are buttoning it up.
Old Dec 15, 2008 | 01:52 PM
Bigfwt04's Avatar
Bigfwt04
I just changed the filter and need to the exact same thing, thx guys
