Replace Negative Battery Cable
Old Dec 15, 2008 | 08:35 AM
angelo's Avatar
angelo
Hi.
I need to replace the negative battery cable in my 2000 Explorer. Is this just a straight shot to the engine, or does it split off or add other ground wires on the way. I can't tell because it's wrapped in the harness with other cables along side the engine.
Thinking I could run a new cable along side the harness and leave the old one there.
Thanks, Angelo
Old Dec 15, 2008 | 11:00 AM
87 XLT's Avatar
87 XLT
When I had the same problem with my 87 Ranger 3 or 4 years ago, i picked up an 8 inch pig tail from Kragen for 7 or 8 bucks
Cut off the last 8 inches of the battery cable inserted it into the pig tail & tightened the set screw.
Problem solved.
Odds are the only bad part of the cable is at the battery end where acid fumes eat them up.
Old Dec 15, 2008 | 11:29 AM
angelo's Avatar
angelo
Yes it's at the battery end. I already put a cheap terminal end on it but thats "gettin kinda ripe"
I didn't know there was a pigtail available.
I'll check Advance Auto Parts or Pep boys here in PA.
Thanks for the reply.
Angelo
Problem solved.
Old Dec 15, 2008 | 05:34 PM
87 XLT's Avatar
87 XLT
Yeah most parts stores should have it. Good luck with the fix
Truck Guy99
Texas Chapter
Jul 18, 2014 10:13 PM
drogrs8455
1997 - 2003 F150
Dec 15, 2013 09:39 AM
Ol' Clappy
Jun 14, 2013 09:09 AM
96-F150
19
Aug 6, 2006 12:11 AM
angelo
Jul 31, 2006 04:39 PM
