Offroad & 4x4
ford rear axle question
Old Dec 14, 2008 | 11:38 PM
9.ford.5's Avatar
9.ford.5
i was wondering if ford ever had an 8.8 or 9 inch rear axle with limited slip and if so what years and whats the code? i might to do that with the d44 solid in the front an maybe a selectable in front
Old Dec 15, 2008 | 06:38 AM
Opossum's Avatar
Opossum
Yes but they sucked, go aftermarket if you can.
If you have an 8.8 now, there not worth investing in, get a 9"
Old Dec 15, 2008 | 07:09 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
they were both available with a limited slp, but as stated the factory units were not to good.
An aftermarket unit would be your best bet.
Old Dec 16, 2008 | 12:04 AM
9.ford.5's Avatar
9.ford.5
yeah i was hoping for a junkyard deal cause theres no way i can afford anything aftermarket to do with axles cept gears so i guess ill just stick with the 8.8 untill i can afford a selectable and a 9"
but im doing a d44 front hopefully by next summer but i gotta get the rest of the stuff out of the way first
Old Dec 16, 2008 | 01:16 AM
Opossum's Avatar
Opossum
There's lots of junk yard 9"s that will bolt right in.
Old Dec 16, 2008 | 11:29 AM
9.ford.5's Avatar
9.ford.5
exactly but ill wait till i can afford a selectable locker in it too my 8.8 will hold up fine till then
Old Dec 16, 2008 | 01:48 PM
goodB0Y's Avatar
goodB0Y
my buddy did a D44 sas on his 95 F150 and plans on a sterling 10.25 in the rear. His plan is to swap to biger hubs and axles in the D44 and then swap in the 10.25 and have it all 3/4 ton 8 lug...
Old Dec 16, 2008 | 05:05 PM
Ryan50hrl's Avatar
Ryan50hrl
my 8.8 factory limited slip had me rebuild it 3 times.....then i gave up and bought an eaton....
Old Dec 16, 2008 | 05:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the AXLE code on the Warranty Plate or Certification Label begins with a letter, the vehicle has Limited Slip.
If the AXLE code begins with a number: No Limited Slip.
Caveman2851
May 11, 2015 06:13 AM
cdichiar
15
Jun 30, 2014 10:53 PM
driptorch970
2009 - 2014 F150
Dec 16, 2010 04:00 PM
greatdays2gether
Sep 18, 2010 02:03 PM
f-150_38.5s
Feb 25, 2006 04:01 PM
