Sponsored by: Innova
Amp behind the seat.
Old Dec 13, 2008 | 10:58 PM
Will89's Avatar
Will89
I was wondering once you take out the back seat to mount the amp on the wall did everyone take out the covering or did you cut a hole in it so the amp fits with it on our what I would love to hear what everyone has done thanks. It is a 2006 F-150.
Old Dec 13, 2008 | 11:37 PM
ReAX's Avatar
ReAX
I take it you have an extended cab? On a regular and crew cab, there should be plenty of space. If your having to remove stuffing to put the seat back in, it's going to hold a lot of heat. It will probably conk out after a 20 or so minutes of operation depending on the class and output of the amp. If you do go this way, you will need to put in some ventilation, maybe something as simple as 1 1/2 PVC pipe fed by a 12v fan.
rat49f6
Jul 30, 2009 11:44 PM
rustynuts
Mar 6, 2006 01:29 AM
SoCalSuperCrew
2004 - 2008 F150
Jul 2, 2004 10:02 PM
kammots
1978 - 1996 Big Bronco
21
Feb 28, 2004 06:09 PM
txlnghrn
Jun 23, 2003 02:50 AM
