my hack up wireing
Old Dec 13, 2008 | 08:06 PM
joe f350's Avatar
joe f350
my hack up wireing
i have no back brake light not chagering system the truck run off the batteris i think y my glow plugs dont work all the time
Old Dec 13, 2008 | 08:07 PM
joe f350's Avatar
joe f350
i got pics in my gallery
Old Dec 13, 2008 | 08:45 PM
1957F100's Avatar
1957F100
What do you mean by no charging system? The truck cant always just run off of the batteries...something has to be charging them?
Old Dec 13, 2008 | 08:51 PM
joe f350's Avatar
joe f350
the batters gos dead after a few days faster if do use the radio of lights i was driving home and full eltrica falure lights guages radio dash light it happend at night
Old Dec 13, 2008 | 08:57 PM
David85's Avatar
David85
Yup theres some redecorating thats been done in there.
The rear lights could be something in the wiring right at the rear of the truck. Could be some poorly done trailer wiring by some other owner.
The no charging could be a problem with the alternator or the regulator.
Is this a problem that you had since you got the truck?
Old Dec 13, 2008 | 08:58 PM
joe f350's Avatar
joe f350
the not chager start after 3 mouth repaced the alternater thx guy for looking and hereing my ple for help
Old Dec 13, 2008 | 09:04 PM
joe f350's Avatar
joe f350
the guy i bought it from took off a trailer break i have pics of wires hang out form under the dash
Old Dec 13, 2008 | 09:08 PM
David85's Avatar
David85
These trucks have an external regulator for the alternator mounted next to the glow plug relay. About half of it is visible in the picture. Check over all of the connections between the alternator and the regulator. I am seeing a wire that is modified in the picture that seems to go into the regulator, so the charging system may have been tampered with.
Old Dec 13, 2008 | 09:11 PM
David85's Avatar
David85
OK, there is a switch under the dash thats connected to the brake pedal lever. Follow the wires from that switch and see what you find. Chances are its been disconnected.
Old Dec 13, 2008 | 09:12 PM
joe f350's Avatar
joe f350
damn the sliver box right iam bought to take it out behind the wood shed di u have a pick of what it should look like
Old Dec 13, 2008 | 09:15 PM
joe f350's Avatar
joe f350
he dint disconct hs spliced in to ti the wires are stell her and hooked up i take a pick and post towaro this is probely easy or u guy to help me now i have pics
Old Dec 13, 2008 | 09:31 PM
David85's Avatar
David85
I don't have a picture of the regulator, but its the silver thing in the lower edge of your picture.
You can also check to see if the brake light switch works. Some times they can get corroded or dusty.
Old Dec 13, 2008 | 10:44 PM
joe f350's Avatar
joe f350
y would some one do what has been done to this poor truck
Old Dec 14, 2008 | 12:49 AM
rupejosh's Avatar
rupejosh
just looked at your wiring and that looks like a fun project i would probably figure out what they all run to and redo the whole thing the right way.it looks like a pretty good rats nest.you'll get it its just gonna take some time and you will have it goin again.
Old Dec 14, 2008 | 01:34 AM
joe f350's Avatar
joe f350
it run just i dont trust it farther then 100 miles ya i get to rewire it that for the digrams i will have a clue of what iam doing
