need help asap please!!!!
Old Dec 13, 2008 | 05:43 PM
jo7.3idi's Avatar
jo7.3idi
ok guy here is my problem i was checking my glow plugs today and i found one that was broken in half and the threds are still in there. how do i get them out there is nothing sticking out to grab on to? all my other plugs are good
Old Dec 13, 2008 | 06:54 PM
LCAM-01XA's Avatar
LCAM-01XA
Unfortunately the glowplugs screw in the heads of the engine, and not the intake manifold, so removal of the broke has all the potential to get real nasty. However, if you're lucky enough, a simple EZ-out may work? I have my doubts on it, but it may be worth a shot.
Old Dec 13, 2008 | 08:24 PM
jo7.3idi's Avatar
jo7.3idi
yah im going to try that of that dont work what can i do to fix it? this so sucks
Old Dec 13, 2008 | 08:31 PM
AndysFords's Avatar
AndysFords
If the whole thing is broken like you say, DO NOT DRILL IT OUT! When I was working as a diesel mechanic we had a special welding rod, you could weld and bead up all the way from something broke off and weld a nut to it and then turn it out with a wrench. Normally this was used for broken head bolts in big diesel engines, but I think it would work with this too. You need to find a good diesel shop or something of the sorts.
Old Dec 13, 2008 | 08:40 PM
jo7.3idi's Avatar
jo7.3idi
thanks a lot guys for the info. o and can i make a cold air intake for my truck when i had breather and filter off it was sounding awsom when i hit the gas pedel
Old Dec 13, 2008 | 10:07 PM
PLC7.3's Avatar
PLC7.3
If your not worried about removing it right now.......but want the GP controller to work correctly........ You can use the GP connector to connect to another GP suspended away from flammable substances so as not to burn anything. The gp will operate as per normal and cause the controller to do the same.
Then when your more in tune to remove the heads and check other things out, have the broken GP removed.
Old Dec 13, 2008 | 10:20 PM
jo7.3idi's Avatar
jo7.3idi
so i can run it with out that gp hooked up? it wont hert my motor and will that fuel burn or not? in going to back that peace out tomarrow but i need to get it to my diesel mecanics shop.
Old Dec 13, 2008 | 10:24 PM
rupejosh's Avatar
rupejosh
i have pics of the intake i am in the process of re routing to get better air in my gallery
Old Dec 13, 2008 | 10:35 PM
jo7.3idi's Avatar
jo7.3idi
mine is not turbo tho thats the thing
Old Dec 13, 2008 | 10:43 PM
rupejosh's Avatar
rupejosh
oh ok maybe take some of that thin galvanized vent pipe and kinda mould it to your existing intake tube.(im thinkin its oval shaped) and hook that into some pvc pipe maybe?with a cone filter at the end.
Old Dec 13, 2008 | 11:02 PM
jo7.3idi's Avatar
jo7.3idi
the intake hole is round and about 4" or 5" inches round and the black tube coming out of the breather is round to. i was thinkin 5 inch pvc 90 with 5" pipe out with a cone filter i just did not know if it would hurt my engine
Old Dec 14, 2008 | 12:59 AM
rupejosh's Avatar
rupejosh
nope it will work just fine more air in= happier motor.thats pretty much what a turbo does.
Old Dec 14, 2008 | 01:38 AM
LCAM-01XA's Avatar
LCAM-01XA
Okay, how we start with a busted glowplug, but end up with a larger intake plumbing?
Old Dec 14, 2008 | 01:40 AM
jo7.3idi's Avatar
jo7.3idi
cause i asked 2 questions at once lol
