Sponsored by: Kumho
Tires Rub
Old Oct 29, 2001 | 10:37 PM
Traveler's Avatar
Traveler
Tires Rub
I just purchased a 2001 F250 V-10 4x4 from a guy with only 18,000 miles. The truck has a 3" susp. lift with weld wheels and 33" tires. When I turn hard to the right, all is cool. When I turn hard left, I can hear the tires rubbing against the inside of the wheel well. It doesn't hit the metal fender "Flare" but it has broken the plastic inside the well. Do I need to replace this part? How do I prevent it from happening again? Can I remove or cut away a part of the plastic? And why does it only happen when I turn left and not when I turn right? Any help would be great.
Old Oct 31, 2001 | 11:18 PM
85351ho's Avatar
85351ho
Tires Rub
somethings not right, you can run 33's stock
1985 F-150/351Ho/c6/4wd~96,000 miles
1979 F-150extcab4x4/460/c6/6inchlift w/60rear44frnt 4.10 gears, 250 springs
37 boggers
Old Nov 1, 2001 | 08:34 AM
ryanstruck's Avatar
ryanstruck
Tires Rub
Something is definately up there. I don't know about new F-250's, but I know you can run 35's on the 80-96 F-250 HDs without any body or suspension mods. The fact that you have a new 2001 F-250 SD with a 3" lift and are still having problems with little 33's sounds bad. You should have that checked out right away before anything gets seriously damaged if it isn't already. With a 3" lift on a 2001 F-250 Superduty, I would suspect you could run at least 35's no problem, you could most likely stuff some 38's in there pretty easily too without any problems.
Ryan
1986 F-250 HD 4x4
4.10 gears, C6 trany
351W, Edelbrock 351 Performer intake
Edelbrock Performer 600cfm 4bbl carb
Edelbrock Pro-Flo air cleaner
Extreme 4x4 camshaft
Flowmaster 30 series dual exhaust
Custom headers
3" Warn body lift
Old Nov 1, 2001 | 01:25 PM
85351ho's Avatar
85351ho
Tires Rub
double check they are 33's, make sure you do in fact have a lift, are the spring sin the front only made up of two flat leaves?
37 boggers
Old Nov 1, 2001 | 08:24 PM
jevanof's Avatar
jevanof
Tires Rub
mankypro
Nov 12, 2013 12:52 PM
Beerstalker
Mar 8, 2007 02:37 PM
just_brian
Jan 6, 2004 08:28 PM
Bruker
Aerostar
Dec 9, 2003 08:02 PM
calyx
Jun 15, 2000 08:20 AM
