no heat
Old Dec 13, 2008 | 02:40 PM
rustee90-150's Avatar
rustee90-150
no heat
ok so in the summer i put a new heater core in the truck and a new water pump. the summer before that i put in a new double core rad. thay were all leaking originals . now its cold out and i have no heat in the truck the engine comes up to opp temp fine within five minutes. the heater core lines are so hot i can barley hold my hand on them the blend door works fine yet even after half hour drive the air coming out still feels cool there is alot of air coming out it blows fine and all my settings work defreost floor ect just no hot air . its a 90 f150 5spd 302 thnxs.
Old Dec 13, 2008 | 02:55 PM
pc_2000's Avatar
pc_2000
Rustee
I'm having the same problem. I'll be interested to hear a solution to it as well.
Old Dec 13, 2008 | 03:46 PM
ac700wildcat's Avatar
ac700wildcat
Are your heater hoses on the right connections? I seem to remember that if you put them on the wrong parts of the heater core it won't work or something?
Old Dec 13, 2008 | 03:58 PM
pc_2000's Avatar
pc_2000
I know I personally check that and reversed them (they were on wrong from PO) no difference.
Old Dec 13, 2008 | 04:58 PM
Conanski's Avatar
Conanski
You're gonna have to open up the heater box again, there is a lot of cold air getting in there from somewhere, possibly a foreign object preventing the blend door from completely closing.
Old Dec 13, 2008 | 08:41 PM
rustee90-150
i took the cover off the heater core and there was a small gap around all four edges of the heater core so i packed them with foam and tweeked the blend door now i have more heat but still not the same as it use to be im thinking its a low quality core .
Old Dec 14, 2008 | 02:04 AM
Xclimation's Avatar
Xclimation
When I replaced my cooling system a few months ago, the heater hoses were completely blocked. When you say you felt the heater lines, do you mean the hoses that go to and from the heater core to the water pump? Even if they are getting hot, they can still be blocked or partially blocked. They are cheap and easy to replace.
Old Dec 14, 2008 | 08:37 AM
250FOREVER's Avatar
250FOREVER
I had a leaking heater core once and replaced it with an aftermarket , no more leak but poor heat !! . Suffered with it through a few winters till it got even worse , figured the I300 just dint make alot of heat combined with with a cloging core . Replaced it again , marginal improvement !!!! and yet another winter . Then I think I read here something about aftermarket cores not heveing good flows so I replaced it yet again with a factory core , gets good heat now !!!!!!!!!!!!!!!!!
A warmer Mark
earlybird 2
20
Mar 6, 2018 05:40 PM
f100guy
Nov 21, 2011 11:44 AM
Justin's Green Truck
1997 - 2003 F150
Mar 28, 2010 09:12 PM
Propr801
Dec 23, 2008 05:49 AM
Propr801
Dec 19, 2008 06:51 PM
