351 Cleveland?
Old Dec 13, 2008 | 02:27 PM
cr0wnguard's Avatar
cr0wnguard
351 Cleveland?
hi guys I'm new to the forums. I have a '79 f150 4x4 I bought from my wifes cousin for 3000. I've had it couple years and it is time for me to rebuild the engine, problem is not sure what I have. Her cousin said it was a 351 cleveland he put in it but another guy told me it was a 400 modified. How can I tell the difference. It's a huge motor. this is am basing off my experiance with chevy's 350s Cause thats all I have worked on. Any pointers?
Old Dec 13, 2008 | 02:40 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Welcome to FTE.
If you click this link and scroll down, you'll find some tips for distinguishing a 351C from a 351M:
Google Image Result for http://www.karmustang.com/assets/351_Cleveland_1.jpg
I believe that other than the bell housing bolt pattern, the 400M looks the same as the 351M.
Old Dec 13, 2008 | 02:45 PM
bashby's Avatar
bashby
there should be casting #'s behind the starter or possibly drivers side of block in same area. here is a code decoder (that doesnt sound right)
https://www.ford-trucks.com/forums/3...6-10-06-a.html
Old Dec 13, 2008 | 02:50 PM
cr0wnguard's Avatar
cr0wnguard
cool thx for the info. Me and my brother fixen to pull engine and tranny. The water does go into the block like the pic for the Cleveland does. Is there a difference between the 351C and 351M? I apologize for all these noob questions I just want to get it right. This truck would spin all 4 of the 35x15.5
swamers that it wore at one time. I want it to do it again so i want to do this right.
Old Dec 13, 2008 | 09:12 PM
85e150's Avatar
85e150
You probably have an M. The C motor had a lower deck height, more in line with a 350 Chev. The M had a tall deck, about as high as a 460, and taller than an FE. Thus, the huge appearance.
Check this info. These engines can be made into good performers.
https://www.ford-trucks.com/article/...00_Engine.html
http://www.fordmuscle.com/archives/2...d400/index.php
http://www.tmeyerinc.com/
