NEWBY here need help!!!!
Old Dec 10, 2008 | 09:35 PM
goodoleboy62's Avatar
goodoleboy62
Hey guys i have a old worn out 351W with about 500,000 miles on it. It has no power what so ever. it gets 6-10mpg and I think its time to rebuild it. How much does it cost to rebuild a 351W? I dont need a really high HP motor just something for a every day driver and light offroading here and there. Also I went to muffler masters the other day and asked if they could run true duals on my truck, they said that it cant be done that a y pipe is needed. Has anyone run true duals on there truck? Thanks.
Old Dec 10, 2008 | 09:36 PM
goodoleboy62
i forgot to mention my truck...its a 1985 F-150 with a 351W auto 4x4, reg cab shortbed.
Old Dec 11, 2008 | 07:35 AM
MBDiagMan's Avatar
MBDiagMan
How long is a rope? That's the sort of question you are asking when you ask how much it will cost to rebuild an engine.
There is just no way to answer that question until it is torn apart and everything is inspected and measured.
That said, the way you describe it, this one is TRULY worn out. If you are planning on driving it in and out of a shop without doing anything yourself and you want a stock rebuild, depending upon where you're located, I think you are looking at about $3,000 and up.
If you want to buy a short block or long block and do the work yourself, you might get by for about $1,500. If you're an experienced motor builder it will still cost at least that, but you could come out with a better result.
Hope this helps.
Old Dec 11, 2008 | 08:17 AM
1dieselman's Avatar
1dieselman
Who ever told you you can't run duals on that truck must be on crack, That one is easy to change to dual exhaust. With that many miles on that engine you would need to tear it down first to see if anything is reusable before figuring out cost to rebuild, might be better off looking in salvage yards, ebay, craigslist,etc for another engine, with way less miles
Old Dec 11, 2008 | 11:56 AM
goodoleboy62
thanks alot for the info. I really appreciate it.
Old Dec 14, 2008 | 10:15 PM
393STROKER's Avatar
393STROKER
Dualed Out
Ya, sounds like new engine time. Try one of those places that sells rebuilds for cheap, like maybe your used core and $600. For the exhaust on my `90 F-150 I got headers that I welded smog tubes on , and made a T to split the air injection from the smog pump, and welded a bung for the O2 sensor.Works goood!
Old Dec 15, 2008 | 10:48 AM
goodoleboy62
thanks man. Yeah a local rebuild shop has a rebuilt 390 for 1200.00 would that fit in my truck? How good are the engines?
Old Dec 15, 2008 | 11:49 AM
393STROKER's Avatar
393STROKER
Thumbs up keep it simple
get a rebuilt 351w long block, the 390 swap aint worth the hassel,trans. is different among alot of other stuff.
Old Dec 15, 2008 | 12:01 PM
1dieselman's Avatar
1dieselman
Save yourself the hassle, put a windsor back in it, if you want some power look into building a stroker engine off the 351 block.
Old Dec 15, 2008 | 05:14 PM
goodoleboy62
thanks im going to look into the stroker kit. what do they normally cost to build a 351W stroker?
strokin'_tatsch
76
Jun 15, 2018 05:27 AM
DoesItReallyMatter?
85
Apr 23, 2014 07:32 AM
Stewart_H
Feb 1, 2012 11:49 PM
goodoleboy62
Dec 11, 2008 11:53 AM
wyazel1
Jul 20, 2008 01:27 PM
