No Power?
Old Dec 12, 2008 | 09:47 PM
315SUPERDUTY's Avatar
315SUPERDUTY
Post No Power?
I have 01 F250 with a banks stinger kit and 4in exhaust no muffler. I live in by lake Ontario and it gets cold. This is the first year I have had to use anti gel. I dont know if that's whats fixing the problem. You take off the truck takes a bit to get it going and it will spit and sputter and then take off with power again. Its been coming and going for two weeks and I cant figure it out.
Old Dec 12, 2008 | 09:51 PM
4inchlovin's Avatar
4inchlovin
Welcome to FTE!!! i would start by removing your chip and see if that makes a difference...
Is there any consistency to it doing this at all? Or is it more random. Do the RPM'S drop when this happens? Or is it more like you are hitting and letting off the throttle?
Old Dec 12, 2008 | 09:52 PM
bdrummonds's Avatar
bdrummonds
how long since oil and filter, and fuel filter has been changed?
Is it only doing this when the truck is cold (i.e. starting up and pulling out of the driveway in the morning without letting it warm up ) or does it do it whent he truck is warm?
Old Dec 12, 2008 | 11:34 PM
315SUPERDUTY
Post No Power
The trucks gauge is ready normal but it feels like your driving it when its cold. What I dont under stand is I have changed the fuel filter the oil and had the trans flushed and filled. I put the anti gel in last time and it worked this time nothing its doing nothing. I had a super chip on it but its turn off and only use it to find codes but there are none. The truck has 205K and ran good up until a few weeks ago. What does the light on the shifter flashing mean?
Old Dec 13, 2008 | 01:08 AM
Smokin''s Avatar
Smokin'
Smokin
OD light flashing on the column shift is a warning that there is a problem and that codes are stored. Are you sure you are reading codes correctly?
A flashing OD light usually points to a transmission or TC issue. Any black smoke, or is it shifting hard? SES light?
Id find a mechanic with a scan tool and have the truck scanned again.
Old Dec 13, 2008 | 01:41 AM
4inchlovin's Avatar
4inchlovin
Ditto Flashing OD light means tranny problem. More then likely your Torque Converter is going south or having an issue functioning properly...
Old Dec 13, 2008 | 12:23 PM
315SUPERDUTY
The light sounds about right. I had taken off the tc awile ago and can the torque converter work and stop workin like that. Today I drove the truck and its fine full power with 22 lbs of boost. Thank you for all the info.
Old Dec 13, 2008 | 04:18 PM
Smokin''s Avatar
Smokin'
Smokin
I'm not sure. Definitely a good idea to get the truck scanned with a proper scanning device.
Old Dec 13, 2008 | 05:12 PM
F350-6's Avatar
F350-6
Just a thought, but is this your first winter running ULSD? Any biodiesel mixed in? You may just have to start running anti-gel. Next time you fill up, find yourself a clear bottle and put about 1 liter of fuel into the bottle from the pump without any anti-gel treatment. I'd keep using the treatment in your truck, but leave the bottle outside overnight and see if the fuel has started to gel in the bottle.
Old Dec 13, 2008 | 10:48 PM
05chop's Avatar
05chop
Most of the time fuel is going to Gel at the fuel filter not in a jar outside.
Old Dec 17, 2008 | 03:09 PM
315SUPERDUTY
It was the TC thanks for all the info.
Old Sep 12, 2009 | 06:00 PM
315SUPERDUTY
do you know how to unstall the factory alarm
