There are a couple different power distribution blocks in the Super Futy trucks. One is behind the plastic panel underneath the steering wheel, the other is underneath the hood near the brake master cylinder and driver side fender.
The Owner's guide has a listing for most of the fuses and relays in it (for some reason Ford left the under hood power distribution box out of some Owner's guides, so it might not be in yours).
Ok......... I just stumbled on to this thread. I am having the same problem.
There is no AUX Fuse block under the hood by the master cyclinder. The haynes book said that in 02's the aux fuse block is behind the glove box. But NOOOOOOOOOOOOOo! I don't believe it's there either... unless you have to take 14-16 bolts out of a large plastic cover that says nothing about fuses or relays.
thanks to all who replied what happend is i jumped my truck and losts all gages,radio,interior lights, and power windows. no fuses were blown no juntion block was ever found in 03 f250. went to electrical shop and to fix ploblem unpluged battery for 15min. plug back in.
