please please help! revving problems!
Old Dec 12, 2008 | 12:26 AM
n_ueland015's Avatar
n_ueland015
Unhappy please please help! revving problems!
ok. i have a 1989 ford f-150 with a 302. i just put a different motor in it, and here is my problem. sometimes when i start it it will run good, and rev to at leat 5,000 rpm's, then i shut it off and it will rev real slow to 3'500 rpm's maybe if i'm lucky. i have changed fuel pump,fuel filter,coil,distributor,ecm,tps. my comprssion is 125 to 145psi. i have been at this for a month now and i don't have no clue what else to do. I really really need some help here. please any suggestions i will try!
Old Dec 12, 2008 | 09:57 AM
Conanski's Avatar
Conanski
Have you pulled codes? It's very simple and will tell you if the computer is having a problem with a sensor or not.
Old Dec 12, 2008 | 10:29 AM
Opossum's Avatar
Opossum
Make sure the timing is active and not acting like the spout is disconnected?
Have you been able to check fuel pressure?
Old Dec 12, 2008 | 11:51 AM
Kemicalburns's Avatar
Kemicalburns
did you install a stock replacment motor for that year? pull codes and check fuel pressue like mentiond above.
