I have a 96 7.3 powerstroke turbo diesel and I would like to know how i can make this thing smoke more I bought a edge evolution performance chip for it and I also have a 3" straight exhaust but it just doesn't smoke enough for me so can anyone help me out
Welcome to FTE. It's a resistor that you wire into the ICP sensor that fools the computer and causes it to increase the pressure in the oil rails and the injectors to dump more fuel in the cylinders. Depending on what year model truck you have, some have been playing with 14.7k, 20k, and even 39k resistors, but since custom tuning has evolved, you're typically better off going with a chip like DP-Tuner or Total Diesel Performance for the 7.3 motors.
Scroll further down the main forum listing and find the diesel section with your model motor and you'll get much more info on this.
chris i have with num 3 and 8 cyl buzz test on injectors is good and i have white smoke a little black at times where do i start my truck is 2001
What color CPS are you running? The gray one has been known to cause fault codes on 3 & 8. What are you using to pull the codes and do the tests? Can you give us rotational velocity (perdel) numbers on your cylinders?
A 3" exhaust isn't gonna cut it my man! 3.5" at least, 4" or 5" is best. Bigger injectors, custom tuning... the list goes on. Go to the OBS PSD forum and do a search, there is tons of info in there.
