leveling kit and lift kit?
DO NOT RUN A BODY LIFT on a 04-08 F-150
they are dangerous, a headache, and not worth the trouble.
I know you have your heart set on those 35" tires. We can get you there, but you need to do it properly.
And unfortunately, Properly = Expensive = Suspension Lift
There are tricks to get to your goal...which I put below
Here is a parts list you will need to run 35" tires...I don't suggest it, but it will work. By doing this, your upper/lower control arms will have some pretty good angles on them. This may cause the ball joints to wear out sooner than designed.
Front End:Rear End:
Auto_Springs 1 1/2" Rear Block for 2wd
or
OEM 2" 4x4 Rear Block (sorry, no link. You'll have to find one for sale somewhere)
or
You will need all three of those items. The front will get lifted 3.5 to 4" and will be the same height as my truck is right now. The rear block will put you within 1/2" the height of a stock 4x4.
I personally would just do the 2" front leveling kit and run a nice 33" mud terrain. It will fill your wheel well rather nicely, and have minimal affect on the front end components.
btw, what is your budget? You can buy a Pro-Comp 6" suspension lift for $1,200 right now
robs01f250
09-09-2010 12:47 PM
