Sponsored by: Kumho
1979 35's
Old Oct 19, 2001 | 06:25 PM
1GRK2's Avatar
1GRK2
1979 35's
I have an 1979 f150, can i fit 35x12.5 with a 2.5 inch lift. and where online can i buy the front lift coils to do it. i also want to replace the rear springs any suggestions on where i can find the parts. i know of superlift, ranch, ect. but i am interested in a site where i can purchase the items. thanks
Old Oct 20, 2001 | 12:56 PM
nick1's Avatar
nick1
1979 35's
Yes you will be able to fit 35's with the 2.5 inch lift. National Tire and Wheel (ntwonline.com) is a good place to order from. If you get a suspension system which is with rear springs its going to be alot more money than the kit which will come with an add-a-leaf or blocks. A lot of money to spend on just 2.5 inches in my opinion. When you order it make sure you get everything you'll need: coils springs, lift for the rear, shocks, c-bushings or radius arm drop brackets. I dont think you need a pitman arm for just 2.5 inches. Brake lines and driveshafts will be fine.
Old Nov 25, 2001 | 07:00 PM
red_rocket's Avatar
red_rocket
1979 35's
all you will need is springs and c bueshings for the front, blocks and u bolts for the rear, and shocks. nothing else. I belive JC whitney sells the whole works from tuff country for about 250-300$
Old Nov 25, 2001 | 07:07 PM
red_rocket's Avatar
red_rocket
1979 35's
