Rear Blower
Old Dec 11, 2008 | 03:42 PM
racerx6466's Avatar
racerx6466
Rear Blower
The rear fan in my 2002 Excursion doesn't shut off (with truck on). With the switch in the off position it still blows on the lowest setting, with all of the other settings working fine. Switch, Motor, Relay? It had a leak coming from the top of the quarter glass over the blower motor
Old Dec 12, 2008 | 08:28 AM
MarkMoore's Avatar
MarkMoore
Do you have front and rear overhead controls? I do and sometimes that messes me up on the functions... just a thought.
Old Dec 12, 2008 | 12:54 PM
racerx6466's Avatar
racerx6466
Yeah but even when the front is in the off position it will still run in the low setting. Every now and then it will work right but it is few and far between
Old Dec 12, 2008 | 08:46 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
What was the cause of the leak, every once and a while there are water drops on the plastic moulding on the rear passenger quarter window? It hasn't been that often or much to have been a concern, but since I saw it in your post I thought I'd ask.
Old Dec 13, 2008 | 07:35 PM
racerx6466's Avatar
racerx6466
I think the glass has been replaced at one time, I bought the truck used. When I hose the window water leak down the headliner and down the inside of the plastic panel covering the back pillar
Old Dec 13, 2008 | 07:40 PM
sddesigns's Avatar
sddesigns
FTE Emeritus
Ok, did it ever stop leaking or is it still a problem?
