Sponsored by: Auxito
Shift Kits
Old Mar 21, 2000 | 08:59 PM
Brad D's Avatar
Brad D
Shift Kits
I have a 97 F150 4x4 with the 4.6 litre V8. I pull a 25 foot travel trailor and live in Washington State where there are several passes and hilly areas. I normally dont have a problem with power, but would like to stiffen up the shifts when pulling. I've heard that B & M has a kit, and Banks has something called a Trans Pak kit, which is better or easier to install? Do either void warranties?
Any suggestions are appreciated.
Old Apr 12, 2000 | 04:08 PM
valkyrie's Avatar
valkyrie
Shift Kits
Go to B&M's site (sorry, don't have the URL.Try a search )
They've got a switch that changes the shift timing and I believe the firmness.
Kind of works like the one on new GM trucks except you get 2 tow settings.
Old Apr 15, 2000 | 10:06 PM
Ultramagdan's Avatar
Ultramagdan
Shift Kits
Get a chip! It will improve your gas use and power. Also you can remove it before you go into the shop. A B&M shift kit is nice but a chip is better. Anytime you modify the stock truck Ford will frown upon it. How Friendly is your dealer?
Old Apr 17, 2000 | 08:56 PM
AlM's Avatar
AlM
Shift Kits
gonefission
13
Aug 28, 2014 02:16 PM
funzjb1
Oct 24, 2012 11:05 AM
Doomsday dually
Mar 2, 2012 06:58 PM
kwob
100
Mar 16, 2005 04:38 PM
mstennes
New Member Introductions
Dec 12, 2004 02:41 PM
