No power obd / hard start / miss??
I have a 2002 F550, 7.3 PS. Increase problem with starting, even when temps are 50 and above. Truck will stumble with no power until op temp is reached, then seems to run fine. Engine light is on when you are in the throttle and off when not... or vise versa... but not steady. Went to have it checked out and no power to OBD port or cig lighter but fuse is good???
Glow plugs OK. Had problem with waste gate actuator, repaired, might be an issue??? Truck blows white/blue smoke when rev'd hard????
Any ideas?
R.G.
Any ideas?
R.G.
Any ideas?
R.G.
Any ideas?
R.G.
Is it the engine light, or the fuel filter light? Sounds like the fuel filter light. Have you changed the filter lately? Also, when you have the filter out, on the right side of the filter housing near the top, there is the fuel outlet that goes to the regulator, and then to the heads. If you look inside that hole, carefully, you will see a screen, that sometimes plugs up. There are 2 10mm bolts on the outside of it that if you remove, you can pull the regulator off the housing and clean the screen. Be careful not to lose the o-ring, and be sure to line it up good when re-installing it. Now, what I do instead of removing the 10mm bolts, I open the drain valve on the filter housing, and with the filter removed, I spray it out with PB Blaster or WD-40, whichever I have available at the time, and I rinse the filter housing out. Be sure you're outside when doing this. You'll lose about a qt of fuel. I then fill the housing up with tranny fluid or diesel fuel, leave enough room for the filter, and install the filter.
Any ideas?
R.G.
Any ideas?
R.G.
I'm betting that once you get that issue resolved the truck will run correctly.
