Sponsored by: Real Truck
Track Bar Removal
Old Dec 9, 2008 | 09:54 PM
grinekb's Avatar
grinekb
Track Bar Removal
I just wanna to check to make sure there isnt a trick to removing the stock track bar on an 03 f350. I was rushed the first time i did it and the air gun wouldnt budge it so i figure i just got to get a really long breaker bar. But just in case is there a trick?
Old Dec 9, 2008 | 10:07 PM
Monster-4's Avatar
Monster-4
Just a big breaker bar, some grunting and a little bit of cursing.
Old Dec 9, 2008 | 10:32 PM
aldridgec's Avatar
aldridgec
The bolt spec is 300 to 400 ft lbs iirc, so it will be tight.
Old Dec 9, 2008 | 10:43 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The upper end bracket bolt and nut is 406 ft-lbs, the lower ball joint end is only 184 ft-lbs.
But's thats listed under RWD 450/550 in the workshop manual. The 4WD 250/350 links to that section, so I assume it's all the same deal, just saving space in the manuals.
Old Dec 10, 2008 | 07:47 AM
Monster-4's Avatar
Monster-4
It's also 406 Ft-lbs for F250/F350 for the upper mount. 183 Ft-lbs for lower mount.
https://www.motorcraftservice.com/pu...20/S3OMAIN.HTM
