need help upgrades for 460 cam mostly
,my heads say d3ve a2a and i do have a lifter problem a little but i cant adjust my valves so the mech i had put on my stuff would not touch them put y truck back together and called me and told me oh yeah we didnt do it you got to go get someelse do do the whole job again and.... needless to say after he messed that up he messed up my intake by leaving stuff unconected i had a vacume which meesed up everything ie timing and so i took it to a diff mech and he tuned it in for my put it on his aircare and it passed with flying colors if that help u guys help me anybetter i will get my trans /converter checked/tested like you said and get back to you guys as soon as i can. how can i tell if i have a dana 40 or 60 front axle? and i know this is stupid but i do just regear the rear end with 5:13 gears right?? and if i do and deside i dont like the 44s can i go back to the 38s?which i might not use due to my 38.5 hitting my power assist steering unit beside the left tire when sharper turning. i read if i go full power steering this will solve this problem. or should i just wheel spacers? steering seems soft enouph to me? and i just replaced the power assist unit with a fresh rebuilt one a couple weeks ago so if i dont have a dana 60 up front im going to stay on 38s for a few years and go with 1.5 inch per side wheel spacers.
Monsterbaby: Scott had to spend alot of time to figure out how to port them heads so the work worth two salts, most joes do not have their own flow bench to test their backyard porting. Last I checked, he did have a nice writeup on how to get some decent numbers outta a set of d3's. I think "some" of the allure of the D3 over the C8, C9 and D0 heads were the fact that they were bolt on horsepower for a bone stock engine, with the pistons .035 in the hole, even if it was only 10-20 HP improvement. I noticed an immediate improvement when I put my D0's on my bone stock 460. If I build another 460, this time around I will go flattops, zero decked block, and some D3s because I have them laying around with the same kind of effort I put into the D0's to see how well they work, AND save $100-200 for D0 cores to start with. If I had the extra bread, I would go aluminum anything, and aim for a little bit more compression than I would with an iron head. That being said however, I do not have $6K to sink into an engine, hell, my last motor I built I easily had 3K into, but boy was it fun! The argument I am waiting to see is why it makes sense to build a stroker, why waste your money trying to make power with a stock stroke.....
From what I understand the D3's have a deeper quench pocket, which makes the exhaust port have more of a dog leg, and less flow-from what I have read. As for flow, going past .500" valve lift gets dangerous-high wear, and in need of roller cam/rockers, and still will have increased valve guide wear. The 385 series are bad for weak valve springs, and breaking springs-been there.
And yes, running a "straight up" timing chain in the 460's is better for low end and mileage. As far as I know, D3 and up parts are meant only for emission bandaids, not power(stock).
Things are different today however, you can take-say a stock mid 70's 460, like the op's
overhaul it with some flat top pistons, or not-and choose a very good cam for it. Today, its mostly all custom camshafts-or very knowledgeable cam guys.Myself, am at a standpoint-rebuild my C8's, or just get some aluminum ones-btw, any recomendations!!?? Heh, here is some comedy-talked to a local machine shop(only one around)-who does not rebuild engines. Asked what they could do, and the shop manager said "huh, I drive a honda" I coulda slapped him.
So I guess I get to order a pre-built custom shortblock, and some kind of heads-cause nothin honda makes will live under my hood! I would make sure of it
little off topic, but hope it helps
As sold by ford the D0VE heads use the same exact valves as the 351c 2V motor, you know the LOW performance cleveland small block, and in fact it's also the same valves as used in the 351M/400 now there is a powerhouse HP building machine from the factory.
Yes Scott has spent time (which is why I say he is about the best in the country for porting stock configuration heads, even kaase had him do the port work to come up with the final casting shape for the P51 heads) BUT what Scott and almost every other major BBF builder knows is that the flow of the D3VE heads are equal to the early heads in all respects both as cast and ported. Plus the HP potential is every bit as high and in fact there is several guys making north of 700hp using well ported D3VE heads.
The D0VE heads also tend to get guys in trouble when building strokers because of the small chambers, someone tells the guy building a street stroker to buy a set of D0VE heads then finds out after spending all the money to go through them that on a 521 even with 36CC dish pistons you are still over 10:1 compression which really isn't conducive to using pump gas with an iron head.
So as I originally stated it's a myth that the D0VE heads are bolt on performance or even remotely a good investment if your looking for power, unless you are wanting or needing to run an iron headed race gas only engine and even then there better choice would be D2OE, or D00E-R.
so should i just keep my heads i have on then or should i do as you said and custom the ones i have? i checked out the rmp heads, for a complete head its 1k each....ouch. If im not running 44 should i got with 4:88 gears then? and i looked into the cam when i got to the shop buddy was like there is 6 cams for your 460 from voodoo/ilunati so what is the one i need? i told him i know i need an rv cam and he looked at my like i was on drugs lol
i realy want to put a cam in the truck
im no gearhead but i sure like the sound of a nice cam +the benifits it will give me makes me think its a no brainer but im going to get the gears done first im going to do this my self i think just need to find a friend that know how so i dont mess and feed him beer for sitting there watching me lol,my trans does clunk a little bit i notice somtimes much worse than othere when going into 2nd, 3rd gears is always nice and smooth so im going to take care of this right after i do the gears. any sugestions for my trans?
).. You CAN get a cool, beefy sound out of your 460 though through maybe a pair of series 40 Flowmaster mufflers...
you may have a corroded timing cover, the water pump and timing cover bolts often corroded due to the iron and aluminum sandwiched together. or a rotted water pump backing plate.
