Buzzer
Old Dec 9, 2008 | 02:29 PM
CDF302v8's Avatar
CDF302v8
Buzzer
Hi,
I have a 1985 Ford F-150, and isn't there supposed to be a buzzer when you first start it? If so, mine doesn't work, and how do you get it to work again?
Thanks.
Old Dec 9, 2008 | 05:21 PM
CDF302v8's Avatar
CDF302v8
Is it just a unhooked wire or something?
Old Dec 9, 2008 | 07:11 PM
mds47588's Avatar
mds47588
Mine is a '86 and I'm sure it's the same deal. The buzzer works when the key is in the ingnition switch and in the off position, and the door is opened to where the dome light is on. The buzzer is located directly above the center of the glovebox door. Easy to reach up and it simply twists out. Then you'll see the plug to disconnect. The one that was in mine was barely working as I could sneeze inside the truck (literally) and it would go off or on. Very intermittant, but I replaced it now and it works fine.
Old Dec 9, 2008 | 07:30 PM
CDF302v8's Avatar
CDF302v8
Okay, thanks! I will see if it is still connected.
Old Dec 10, 2008 | 12:29 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Fasten belt warning buzzer will sound if you are not wearing your seatbelt, and you start the truck. The Fasten Belts light will shine, if you are buckled in or not, when you start it.
Old Dec 10, 2008 | 12:46 AM
Ken Blythen's Avatar
Ken Blythen
It may have been unplugged behind the seat. I've done this to mine - the screaming tone of it drove me mad.
There is a connector at the bottom end of the seat belt strap that plugs into wiring coming from under the carpet. Unplugging at this connector doesn't affect the warning light on the dash
Old Dec 10, 2008 | 02:26 AM
Ken Blythen
I might not have been clear in the previous post.
The buzzer connector is on the bottom end of the fixed belt strap that goes down through the seat base - not on the retracting part of the belt
Old Dec 10, 2008 | 07:32 AM
CDF302v8's Avatar
CDF302v8
Thanks! i will look for it, and see if it is still connected.
