exhaust smell
Old Dec 8, 2008 | 03:33 PM
fordxl68's Avatar
fordxl68
exhaust smell
I have a exhaust smell that comes from the heat or a/c vents when on and goes away when you turn on recirc.took it to ford twice first time they said cant find problem. took it back second time for same problem and they said the only exhaust leak was from cat back system. I had that small leak fixed even though it was leaking just in front of muffler which is by the back door. The shop that fixed that leak said it had a bad leak where the cross over pipes meet just under the back part of the engine. thats why it smells in the engine compartment.ant comes through the heater box. my ? is where does the heater box get it outside air from? I dont want to take it back to that dealership again, I had some bad words with them the last time they said it was only leaking from catback. lucky for them that I only buy Fords. or I would switch next time. Like they care!
Old Dec 8, 2008 | 05:36 PM
Buck 1's Avatar
Buck 1
Are you sure it is an exhaust smell, or could it be a normal heat smell from the engine? In any case, I would spray some type of fragrance into the vents, and see in a day or two if the smell returns.
aaronbwy
2009 - 2014 F150
Dec 10, 2014 07:30 AM
Nick Burnett
Oct 8, 2013 03:29 PM
EODguyJake
Dec 5, 2010 02:18 PM
pdqtimetrialer
Nov 14, 2009 10:44 PM
xboxundone
1997 - 2003 F150
May 21, 2004 08:27 PM
