i need a t19 for a 6.9 diesel 4x4 1984 i found one out of an old gasser but am not sure if its a 460 or not can these bolt up to a diesel anyway if its two wheel drive or if its a smaller motor than a 460?
The bell housing for a 460 (or any other motor) won't bolt up to your diesel but I THINK if you already have the bell housing the T-19 off of any motor will bolt to it.
The t-18 and 19 used the same input shafts,as far as Ford trucks were concerned. I have a t-18 behind a 6.9. You do need a diesel bell housing or a few machine shop tools to make the mod.
The T 19 bolts to a bell housing.
All the rest of the transmissions have integral bell housings made on the transmission case.
That fact makes the T 19 the only transmission you can swap between a diesel and gas engine without modifications to the transmission.
A 460 gas engine is close, but it will not bolt up.
I have the t-19 in my 86 6.9. For the most part it is ok. Pulling a load on the flats, it starts off ok.
But if you are on a hill, you have to play with the clutch to get her rolling.
I have the 3:55 Differential. With the 4:10 Differential it would probably get rolling ok.
The gasser t-19 doesn't have granny low, but it is lower than the diesel.
Back in the day they actually offered a kit, to regear the diesel tranny to the gasser first gear for heavy load applications.
Good to know, I thought it had the Granny Low.
I do have a 3 speed Brownie I would like to install. Deep under, Direct and OD.
Picked it up with all the drive lines, and shifter for $275.
Problem is the front fuel tank it a foot too long with standard Cab.
Charlie
That's a really good deal! Some of those boxes fetch more than they're worth sometimes.
And on mine there already isn't much room between the transfer case and the fuel tank so I know exactly what your talking about. I guess you can remove it and go with that large bronco rear tank everyone loves.
