Ford AIS
Old Dec 10, 2008 | 07:51 AM
SGnAZ's Avatar
SGnAZ
Originally Posted by Ponyboychris
I really like my AIS. Stops a lot of crud even with a zoodad mod. Got my unit from Your Premiere Source for Ford Truck Parts | Powerstrokeshop.com.
Is this a pretty straight forward install? Do you have a pic of it under the hood?
Old Dec 10, 2008 | 08:04 AM
rbaker6336's Avatar
rbaker6336
the install takes about 20 minutes if you goof off a bunch
Old Dec 10, 2008 | 08:08 AM
SGnAZ's Avatar
SGnAZ
Thanks,30 for me-I tend to goof off alot
Old Dec 10, 2008 | 09:57 AM
USAF CCM's Avatar
USAF CCM
I installed the AIS shortly after Ford came out with this option in 2003. I bought it from the Ford dealer I ordered/purchased my truck from; Wilmes Ford in Altus OK. Since they were working on fixing an oil leak near the oil pan (engine out) they just stuck this one back in. I'm a firm believer in filtration first, flow second.
Fast forward to June this year. I had Jody doing live tuning when I purchased my DP tuner. He said I'd peg the filter minder without getting more air to the turbo. Well we didn't.....during the live tuning. But I did after departing for home and many times in the following weeks. I started seeing more black smoke (unintentional) and felt a SOPT lack of power.
I knew it wasn't getting enough air to the engine so I swallowed hard, cut a hole in the side of my AIS and installed the fender sleeve. I also did a modified ZooDad mod. WOW! Instantly I noticed the truck moved quicker off the line, no more smoke and my filter minder hasn't moved since, even after flooring the truck in 120 HP tune. I'm very happy with this result. I know my truck is getting the cleanest air possible and she moves like a race car, but pulls like a tractor. On a recent deer hunting trip towing my 31' TT I used DP's 40 HP tow mode. I saved almost 1/2 tank of diesel on the same trip I've made numerous times. Oh, and the truck never once downshifted from overdrive to third. What a pleasure to tow with!
Man, I love this truck!
Old Dec 10, 2008 | 10:32 AM
PaysonPSD's Avatar
PaysonPSD
AIS in my early 99.
Old Dec 10, 2008 | 10:59 AM
jdecker88's Avatar
jdecker88
Looks exactly like the stock set up.
Old Dec 10, 2008 | 11:06 AM
UP_There's Avatar
UP_There
I was thinking the same thing. The main reason the stock setup tottally sucked was those clamps never seem to make a snug airtight connection all the way around the box.
Old Dec 10, 2008 | 11:13 AM
jdecker88's Avatar
jdecker88
Maybe Donaldson fixed that problem.
Old Dec 10, 2008 | 11:21 AM
UP_There's Avatar
UP_There
Hopefully they did! This is what happens with a stock airbox and a K & N drop in filter!
Old Dec 10, 2008 | 11:37 AM
jdecker88's Avatar
jdecker88
Crap that things has some sand blasting, was that yours?
Old Dec 10, 2008 | 11:39 AM
UP_There's Avatar
UP_There
Yepp.....and there is a brand new shiny Wicked Wheel in there now
Old Dec 10, 2008 | 11:42 AM
jdecker88's Avatar
jdecker88
I love mine
Old Dec 10, 2008 | 11:51 AM
  #28
PaysonPSD's Avatar
PaysonPSD
Not if you compare it to an early 99 that drew air only through the wheel well. That was a real crappy design. Fortunately I never ran a K&N drop in. The wheel in my old turbo with 98k still looked good.
Old Dec 10, 2008 | 11:56 AM
  #29
Kwikkordead's Avatar
Kwikkordead
I run the AIS too.
Used to run the 6637, but found it was noisy, with a lot of intake drone.
Old Dec 10, 2008 | 11:57 AM
  #30
Ponyboychris's Avatar
Ponyboychris
Robin's picture is what it looks like in a late '99 thru 03 model. Nice, straight forward install. About a 2 beer job. You have to remember also that the filter element is HUGE compared to the stock unit.
