Sponsored by: Real Truck
5.4 header install ?
Old Dec 8, 2008 | 06:24 AM
bad466's Avatar
bad466
Question for those that have put headers on their 5.4. How did you get the nuts off of the old manifolds? Mine are so rusted there round, and most of them you cant get a pair of vice grips on them. I could torch them off but I was trying to make that my last resort. Any help would be appreciated.
Old Dec 8, 2008 | 06:41 AM
ReAX's Avatar
ReAX
I didn't do mine, but there are some options. If they are nuts, then they are on studs which can be removed. You will probably have to remove them anyway to use new bolts. So you can try a stud extractor or just your vicegrips on the studs. You could also try a nut splitter or a chisel. In any case, letting penetrating oil soak in over night and then running the motor a few minutes to get the manifolds warm to the touch will all help.
Old Dec 8, 2008 | 10:33 AM
redford's Avatar
redford
FTE Leadership Emeritus
When you install new headers, get one of the many kits that lock the header bolts down. You won't be sorry.
Old Dec 8, 2008 | 12:13 PM
bad466's Avatar
bad466
I planned on that, I dont wanna be messing around re-torqing header bolts every couple weeks.
Old Dec 8, 2008 | 12:28 PM
ReAX's Avatar
ReAX
Yeah, then just pull the stud and nuts out together.
Old Dec 9, 2008 | 08:10 AM
krewat's Avatar
krewat
Actually, that only needs to be done for the first few weeks or a month or two.
For the headers on my V10, I re-torqued the bolts every few days and it only took a month or two before they tightened up and stopped coming loose.
The reason is, the gasket crushes.
If you DO NOT re-torque the header bolts you WILL have gasket leaks.
So, don't just set-em-and-forget-em. Even with locking header bolts, you SHOULD re-torque until they stop loosening up. It's not the bolts backing out, it's the gasket crushing over time.
rpatrick
May 23, 2016 09:02 AM
das54
21
May 13, 2016 11:06 AM
slowmans
Ford Truck Parts for Sale
Nov 6, 2015 05:13 PM
iuecbrad
1997 - 2003 F150
Sep 20, 2015 12:39 PM
Water_Boy
Feb 14, 2013 01:05 PM
