Hello there. I need to know how to remove the Door panel on the driver side. I've tried already, but it was so hard. I do not want to break it . The reason is, that I need to push the Lock out. The truck is a 99 Dually.
Thank you very much.
Go to this link. Jimmi' Jammer™
It's for installing the Jimmi'Jammer but has great instruction for removing door panel.
Edit: Why do you need to get at the lock cylinder?
Under the light/reflector is a screw. Lift the switch panel up and uplug switchs, one screw behind there. when screws are out. lift straight up. Watch the little light at the bottom of door, wire is only a few inches long.
The cylinder works but, it's pushed in. Somebody was trying to steal the 40 Gallons Diesel tank, that is hooked to the Tool box on the Bed. They couldn't. Then, decided to go for the Truck. I'm Happy the truck still here.
Thank you and the others for the Help. Take care.
Hopefully it is just a bent wire c-clip that holds the cylinder in. And hopefully it is not the plastic that is broken.
