Well, last night on my way out, my turn signals stopped working intermittently.. Then, I go to unlock my doors, and the unlock doesnt work, but lock does..
My Haynes is at the shop, but I was hoping someone had a online reference I might be able to use. The one I posted the other day is shut down..well, at least the password doesnt work.
when this link opens.. top center you will see Auto Repair refrence center logo..click on it..when it opens type in the word "Library" for user name and for the pass word.. click on the auto repair refrence again..click in year of truck..then click on Ford, then on Ford F350 super duty then click on select for 7.3 there you will see Repair Topics: Wiring Diagrams and other info can be found there. they have a lot of good diagrams..you need to look around for them... it takes a little bit to get used to..i hope it helps out...
Same secondary site as the one I listed the other day, must have been you that got me there the first time, thanks.. but I am unable to sign in right now?
Well, I just got into my steering column, I found my tie wraps had shifted, so I think after snugging that up ( under the column there is a multi connector plug that from the get go on my truck has came loose. Normally there is a a series of problems though when this comes loose) I will try again.. Looking more into this door unlock, I am starting to wonder where this door lock/unlock module is..I did learn I can remove fuse 12 and not worry about my day time running lights..
For your door locks, do you have keyless entry or not? If you do, the drivers door is isolated from the other 3 doors. This allows for the driver unlock and the all unlock. If you dont, all four are connected together. Let me check how many pages the lock diagrams cover. I might be able to scan you a copy.
For my Unlock problem, I pulled the plugs to do the continuity test, good. did the continuity test accross the switch, good. Put plugs back on, checked voltages, went from my ground wire to the Pink with LG for unlock, and pushed the pin into the plug.. there it was.. Unlock and lock, done..Thanks Trevor for the print!!!!!!!! By the way, what book did that come from? I would like to track one down and order it.
