Sponsored by: Innova
Blackmore amp question...
Old Dec 6, 2008 | 06:10 AM
Bull_'s Avatar
Bull_
One of my friends has an amplifier that randomly pops, the radio will be at 0 volume and the subs just go nuts for a few seconds. Has anyone else had a similar problem or an idea of whats causing it? I have replaced all of the wiring, and added a capacitor, the only time it doesnt have this problem is when the right rca plug is disconnected.
Old Dec 6, 2008 | 09:26 AM
ReAX's Avatar
ReAX
If disconnecting the RCAs stops the noise, then it's probably ahead of the amp. To test to be sure, take an RCA cable and cut it up, wire the shielding to the center conductor. With this plugged in, if the amp doesn't act up, then the amp is fine.
What is ahead of the amp?
Old Dec 6, 2008 | 09:29 AM
Bull_'s Avatar
Bull_
A VR3 HU he bought to replace the original HU thinking it was the problem. Ill try that this afternoon and update on how it works.
Old Dec 7, 2008 | 01:28 AM
bgalaxy67's Avatar
bgalaxy67
It might an intermittent issue with the RCA's I would change them out. If it still does it then it's going to be the output on the deck.
Old Dec 7, 2008 | 01:44 AM
ReAX's Avatar
ReAX
He needs to test the amp with the dummy RCA first. Then it would be time to try a very short RCA from the HU to amp.
Old Dec 7, 2008 | 02:39 AM
Bull_'s Avatar
Bull_
I have it tracked down to being the right rca input on the amp, and thanks for the help i really appreciate it.
Old Dec 7, 2008 | 03:11 AM
ReAX's Avatar
ReAX
Do you have a DMM? Try measuring the resistance between the chassis of the amp and the outer edge of the RCA connectors. I can't remember the type that should have a resistance, but if you have two different values, that or a ground loop will be your problem.
Old Dec 9, 2008 | 09:16 PM
Bull_'s Avatar
Bull_
Interesting solution
Ok the popping problem is solved, But the solution was to take a 6" rca cable and connect the left output (from the amp, not the radio) to the right input, it works as it should but it only pops when the right channel from the radio is connected.
Old Dec 9, 2008 | 10:43 PM
ReAX's Avatar
ReAX
So the amp is fine then. sounds like either the RCAs or headunit's output are bad. If you want to test further, you can swap right and left on the headunit. However since you have it figured out and working, just put a splitter on the left channel so it inputs both channels on the Amp.
jjenkins816
Apr 25, 2005 09:32 PM
Netpaqer
Oct 7, 2004 07:14 PM
mogulero
Jul 25, 2004 04:21 AM
Hausladen
Modular V8 (4.6L, 5.4L)
25
Apr 5, 2003 08:07 AM
SWT
Sep 13, 2001 03:49 PM
