Sponsored by: Auxito
Engine Speed/Tilting Body
Old Feb 18, 2000 | 10:30 AM
rbobmathews's Avatar
rbobmathews
I bought my first full size truck, a 2000 150XLT with a v6 with a stick shift in November 1999. When shifting the engine speed does not drop when the clutch is engaged; at times it speeds up. Is this due to the cruise control on a stick shift? Also, I find that the left side of the truck drops from 1.5-3.5 inches lower than the right side, depending on whether there is gas in the tank. Is this something I should consider normal?
Old May 6, 2000 | 04:13 AM
Fish's Avatar
Fish
Did you see the recall notices re: cold climate freezing of throttle linkage? Also owners manual states that if battery power is interupted, computer need to reset idle speed, so start truck, and let idle for 30 seconds. I have a 97 and the owners manual states idle control by computer must be reestablished after power loss. Hope this helps.
Old May 6, 2000 | 01:03 PM
NorminN.B.'s Avatar
NorminN.B.
wskline
Dec 12, 2012 10:11 AM
Stephen67
15
Jul 21, 2011 02:00 PM
m42
1997 - 2003 F150
Dec 10, 2006 10:06 PM
ABoyAndHisFord
25
Jun 12, 2005 05:17 PM
XLRanger
Mar 27, 2002 07:19 PM
