Stalled no start
Old Jun 27, 2005 | 01:30 PM
holt12's Avatar
holt12
Stalled no start
1988 F250 5.8 - running down the hiway and then nothing but a $100 tow job. I have fuel and had the ignition module tested, still nothing.
Any thoughts?
Old Jun 27, 2005 | 01:38 PM
pfogle's Avatar
pfogle
Check for spark. Check the fuel pressure. It could be the coil, could be a clogged fuel filter, or bad plugs, wires, cap and rotor.
Old Jun 27, 2005 | 01:43 PM
MemOrex's Avatar
MemOrex
I'm gonna say check the coil.
Old Jun 27, 2005 | 02:49 PM
holt12's Avatar
holt12
OK, I have good fuel pressure. I do have continuity through the coil windings, I have had the ignition module tested - TOK. I am a bit at a loss without buying a few expensive parts and swapping on speculation.
Old Jun 27, 2005 | 03:19 PM
Popa Tim's Avatar
Popa Tim
Do you have spark?
Old Jun 27, 2005 | 03:24 PM
holt12's Avatar
holt12
Sorry, no spark.
Old Jun 27, 2005 | 04:36 PM
Popa Tim's Avatar
Popa Tim
If the coil and TFI are testing good then it sounds like the PIP sensor, located in the distributor, or the computer itself. Can you pull codes, even the "no codes" code would be a good indication the computer is working. Most people replace the whole distributor rather than tear it down to replace the PIP.
Popa Tim
Old Jun 28, 2005 | 09:10 AM
holt12's Avatar
holt12
I think that you may have hit on it. I pulled the distributor, removed the module and did a continuity check on the PIP, one lead to ground - "A" the rest open, no continuity A-B, A-C,C-B,so I see a new distributor in my future vs PIP only.
Thanks in advance for your assistance.
Studawg
Feb 28, 2012 02:40 PM
iwanaflattie
23
Jan 9, 2012 11:44 AM
chrono4
Iowa Chapter
Jul 8, 2005 02:02 AM
dammford
1978 - 1996 Big Bronco
16
Oct 26, 2004 09:35 AM
christop43
Sep 16, 2002 05:45 PM
