what is the best way to find out what motor is is my truck its an 82 f100 but not the original motor. its a small v-8 and the valve covers have 4 bolts each ( 3 on the outside and one in the center of the inside) the block is covered with a layer of oil and crap so i would have to scrub the whole thing down to find the casting number is there any other way to id the motor without the number
It's either a 302 or a 351w. In an F100 it's probably a 302. Look at the thermostat housing, find the lower bolt. Is it partially covered by the water pump?
i will check when i get home but i know that the motor that is in the truck came with a/c because the bracket is still there sticking out like a sore thumb but my truck has no a/c...
the lower thermastat housing bolt on the drivers side is behind the water pump and the housing also has a line to the water pump on the pass side of the housing
it would have to be a 302. The 302 is the biggest motor that came in that generation F-100's. And when you open your hood on just under the front itll have it listed where its listed whether its a catylist truck or not
ok i looked at alot of pics and parts to a 302 and im pretty sure that is what i got so does anyone know where you can get a engine diagram for any of the systems i just want to make sure every thing is where it is supposed to be
helminc.com has the following and all these manuals are new original genuine Ford.
Helm has printed all of Ford's literature for over 60 years.
