well im the trans stuck in reverse guy and i finally figured it out i effed up by takin out the reverse idler arm bolt which dropped the arm into the trans that explains y it was stuck in reverse well i fixed that but also found out there was a spacer and c clip that popped off an got stuck in the gears but i found a good workin trans for only 100 bucks so i buyin it and puttin it in then fix my old one ... o well but thank you all for your help there still are some good guys out there and whoever sent me the whole manual on the t19 double thanks ill be usin this site ALOT now
no lol but dude i found one for 100 bucks so f that i boltin this one up an fix my other im actually thinkin bout buyin 2 i mean 100 bucka a pop cant beat it for a workin trans thats 125 dollars cheaper than a rebuild kit w synchros
I would make sure it has got clean gear oil in it and run it if it doesn't make any noise and sifts good and the shifter is pretty tight it will probably last you forever.
