front bumper questions
Old Dec 3, 2008 | 04:01 PM
peganit2's Avatar
peganit2
The front bumper and mounts are gone from my 77 Highboy. It has been converted to a 78-79 front grille and I want the same year bumper for it.
What brackets would make that work? Does anyone have any pics of what to look for? I can fab, but I don't want to waste energy on something that has a bolt on solution.
And on a related note, does the bumper bolt directly to the frame horns on any 64 through 79 Ford truck?
Thanks in adance to any and all responses.
Old Dec 3, 2008 | 06:57 PM
117wb 4sp.'s Avatar
117wb 4sp.
yes my 77 150 bolts to the frame i can put a yard stick on to see how whyed. can,t spell it. als
Old Dec 3, 2008 | 09:33 PM
plowpusher's Avatar
plowpusher
I had the same problem,my truck came with a winch bumper up front. Hi boys had a bracket that bolted to the outside of the frame rails pointing out because the frames are narrower and the front leaf spring mount frame cross member I tried a couple different ways. First went to the bone yard to find used ones... no luck, cut the ends off a f150 frame to use as brackets too narrow ended up fabricating a set out of 1/4 strap and plate
Old Dec 4, 2008 | 01:01 AM
75F350's Avatar
75F350
The front of the frames are the same width, and the brackets do not have to point out. Spring perches are the same and any front axle from 73 to 79 will bolt right in. Only the 77.5 to 79 trucks had a wider frame in the rear but the front was the same. This makes the frames the same width
Here is a factory 73-77 bumper bracket used with a 79 bumper.
Old Dec 4, 2008 | 06:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79 F250 Front Bumper Brackets / 1973/77 F350
Originally Posted by 117wb 4sp.
yes my 77 150 bolts to the frame i can put a yard stick on to see how wide.
This thread refers to F250's which use bumper brackets, F100/150's do not.
D3TZ17752A .. Right Front Bumper Bracket / Obsolete
Don Sanderson Ford in Glendale AZ has 21 = 623-842-8762
D3TZ17753A .. Left Front Bumper Bracket / Obsolete
Don Sanderson Ford in Glendale AZ has 27.
Green Sales in Cincinnati OH has 1 = 800-543-4959
Miller Obsolete Parts in Binghamton NY has 2 = 800-546-7278.
That's it, no one else has any.
Fits: 1973/79 F250 / 1973/77 F350 (1978/79 F350's use different brackets).
The above are the original part numbers, and the parts are genuine Ford.
Old Dec 4, 2008 | 04:00 PM
peganit2's Avatar
peganit2
This did answer the second of my two questions.
I asked because a local guy with a LOT of Ford truck parts for sell tried to sell me a pre 78 bumper for my Highboy for a good price and he said it would bolt directly to the frame horns. He's a nice guy but I think he's just a little mixed up about Highboys.
I'll keep looking.
Old Dec 4, 2008 | 04:03 PM
peganit2's Avatar
peganit2
Both 2wd and 4wd brackets are the same?
Old Dec 4, 2008 | 04:06 PM
peganit2's Avatar
peganit2
You are a big help numberdummy.
NumberDummy
I asked because a local guy with a LOT of Ford truck parts for sell tried to sell me a pre 78 bumper for my Highboy for a good price and he said it would bolt directly to the frame horns. He's a nice guy but I think he's just a little mixed up about Highboys. I'll keep looking.
Why keep looking?
I found the correct brackets NOS at a Ford dealer in Arizona.
See my post #5 above for all the info.
And yes....the 2WD & 4WD brackets are the same.
Old Dec 4, 2008 | 04:12 PM
peganit2's Avatar
peganit2
Why keep looking?
See my post above.
Yes....the 2WD & 4WD brackets are the same.
Um, you got a strong personality numberdummy.
I'll give em a call but if the prices are beyond what I deam reasonable, I'll keep looking.
Thanks.
For chits and giggles, how about the brackets from a 65 F250? I can get a good bumper and brackets for NOTHING off of a parts truck that I know of.
Cost is a REALLY BIG object.
Grape Nehi
13
Mar 24, 2017 06:45 PM
jerryst
May 29, 2016 08:39 AM
GCLL
6.7L Power Stroke Diesel
43
Dec 14, 2012 11:51 PM
winslow33
May 8, 2012 09:21 AM
1977f150xlt
18
Jun 14, 2009 05:01 PM
