riding rough?
Old Dec 3, 2008 | 03:52 PM
carter442's Avatar
carter442
riding rough?
do the older diesels like my 86 ride rough? is a 3/4 ton xlt lariat how rough r they supposed to b on highways and with hubs locked ?
Old Dec 3, 2008 | 03:55 PM
starmilt's Avatar
starmilt
Compared to what. It should not make any differance weather your hubs are locked or not.
Old Dec 3, 2008 | 03:57 PM
carter442's Avatar
carter442
idk i guess compared to a newer one but at highway speeds my truck is loud and i cant tell if its the motor or something else r these trucks normally loud at highway speeds?
Old Dec 3, 2008 | 04:46 PM
PLC7.3's Avatar
PLC7.3
What tires and how much pressure.......... Any load in the box........
I would say the 84 4x4's were a little harder suspension from what I remember.... The newer trucks have been softened even with the load capability increased. I find mine 93 runs hard unless I have about 300LBs in the box....... so I have a small toolbox and a cap on it.
Old Dec 3, 2008 | 06:05 PM
carter442's Avatar
carter442
um theres no weight and the tires are dominators and idk the pressure right off
Old Dec 3, 2008 | 07:11 PM
joe f350's Avatar
joe f350
my 85 rides like crap my cd player is usless skips to much but mine as 37 and 11 inch lift and a solid front axle
Old Dec 3, 2008 | 07:18 PM
carter442's Avatar
carter442
mine skips to i no what u mean
Old Dec 3, 2008 | 07:20 PM
joe f350's Avatar
joe f350
do u have a tiwn ibean for sold front axle
Old Dec 3, 2008 | 07:22 PM
carter442's Avatar
carter442
twin i beam
Old Dec 3, 2008 | 07:23 PM
joe f350's Avatar
joe f350
u should be ride that ruff
joe f350's Avatar
joe f350
u shouldent ride that ruff
Old Dec 3, 2008 | 08:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The older trucks were more for working than comfort.
I remember when picking your date up in a truck was not a cool thing like it is today.
One thing to look at, how much clearance between the front axle stop and the bump block on the frame?
Other that the shackle bushings being worn out on the front axle, the main reason it rides rough is you can put about 1500 pounds in the back with no problems.
Old Dec 3, 2008 | 08:58 PM
starmilt's Avatar
starmilt
You want rough my first pu was a 63 int the dates allways wanted to take their ride so it worked out allright.
Old Dec 3, 2008 | 09:04 PM
joe f350's Avatar
joe f350
my frist truck was a 1970 internation havster the thing rode like brage in a mosune and tank mix all together
Old Dec 3, 2008 | 10:07 PM
carter442's Avatar
carter442
i no some of it is def from my suspension bein set up for work i got an add a leaf in the back i was told although not sure how reliable that the previous owner hauled a 2000 f250 mega cab without the back saging at all
if i put softer shocks on it like ranchos wood that help? either those or rough country because jcwhitney has a good deal on the rcs
