Wheels And Tires for 87 Bronco
Fellas,
New member, and I just got an 87 full size E.B. Bronco. What are some recommendations for wheel and tire size. I wasn't considering lifting the truck but should I? Maybe a couple inches? If I don't should I stick with 15x10's. Also the lug pattern. Is it 5 on 5.5? Thanks.
With no lift you could go with the 15x10's and some 31x10.5's or maybe some wider 31x12.5's which would be fairly wide and look pretty neat I think. The only problem I can think of would be the backspacing. Make sure your rims have a decent backspacing. If you wanted to go with a 2 or 3 inch lift you could get some 33x12.5's which would be good but the cost gets up there when yout hink you will be spending around $600 or so just on tires before the lift.
Some places do combo packages which might be something to look at. Good Luck
