Hub bearing and seals
Hey guys, I just got finished doing my drivers side hub bearing, all the o-rings and seals. I also did new ceramic brakes and turned the rotors.
For the most part, I followed Guzzles writeup and all went kind of smooth. Untill I go the the large outer stub shaft seal.
What a pita!
Is there a special tool to push that seal onto the outer stub shaft with-out damaging the seal? I used a piece of exhaust tube and did distort it a little, but it seems to still spin fine. I guess the test drive will tell me for sure.
Also, I'm kicking myself in the rear end because after I put the entire thing back together I noticed that I forgot the dust shield for the brake rotor. Doh!
How important is that thing? I'm half tempted to pull everything back apart and do it again but I wanted to hear your guys's advice first. I pull the ones of my offroad rigs because they tend to trap gravel and sqeel like a stuck pig. Are they to keep raod junk off the rotor and out of the brakes? How about cooling? Will they affect the brake cooling at all?
I also used an ABS hub (I have non ABS) because it was new and didnt cost me a penny. I plugged the hole with black RTV and tested the auto lock and everything locked and unlocked just fine. Think it will hold? I love free stuff so I cant moan to much. lol
So, what are your thoughts on all this madness?
What a pita!
That was the easy part.
Getting the new seal in was the hard part. I found a piece of exhast tube that was just big enough to fit the inner metal ring and then tapped it onto the axle stub shaft. Its hard to get that thing on without damaging it so be carefull and take your time.
on
Just found it at Summit Racing for $49.95 Not available until 12/19 though. Looks like it can be found here: http://www.sjdiscounttools.com/otc6695.html
I tried that exact DIY tool. Didn't work for me. Started to deform the seal. I figured it was worth the time and money to let someone with the right tool do the job. Not saying it doesn't work. Just saying it didn't work for me. At all.
