That is amazing Colin, mind if I ask. How much is an amsoil oil change? What filter did ya use?
I have always heard that a syn oil change would last longer, though I changed out my 0-40 coop from last winter with about 7500ish on it.
I think the oil was $6.50/litre but I will check. I am a preferred customer so I get a lot better price than the normal customer. To be a prefered customer costs $30.00/yr, so if you buy lots of oil in a year like I do it pays for itself in a hurry. As for the filter it is just a wix filter. The 5w-40 makes a big difference when it gets colder than -25.
hi guys,
you can get amzoil just about anywhere. 15w40 diesel oil is about 8.50 a qt. but that is good oil. when i worked at clays we used the transmission fluid alot! and i would drain the qt bottles into a bucket,along with dex3,mercon5,amzoil atf,etc. we have to do that
otherwise the trash guys won't take the trash.
hi guys,
i've seen people spend anywhere between $400. and 500. bucks and sometimes more to do the motor,trans,transfercase, and both diffs in 1 shot. with amzoil. matter of fact i bought 4 qts of atf in my ranger the last time i clutched it. that was last summer.
morris, sheldon,
first off my ranger is coming on 187,000 miles and runs good still. i keep it good i love my truck and it has been flawless that truck doesn't have any leaks at all, and it will broil the tires. i just winterize it and my shadow! i have to go up and drain betha the old race car!
sheldon amzoil is worth the money! for what you spend on a oil change every 6000 miles or 10,000 for deisels. it spreads the intervals out alot! from 10,000 to 25,000 miles it will save you some money!
