'85 5.0 EFI problem
Old Aug 9, 2009 | 07:54 PM
CDF302v8's Avatar
CDF302v8
Originally Posted by 1 F150dude
Dont forget to check your fuel pressure regulator. It can make it act funky too.
Where is that located?
Old Aug 9, 2009 | 09:07 PM
baldboyford's Avatar
baldboyford
The fuel pressure regulator is located on the driver's side of the engine back towards the firewall. it is a short cylinder shaped piece that has a vaccuum port on the top of it. It should have a vaccuum hose ran to a vaccuum tree or manifold. It should also have 3 hex head bolts holding it onto the fuel rail.
Last edited by baldboyford; Aug 9, 2009 at 09:13 PM. Reason: Sorry didn't read the post fully, thought I read filter instead of regulator
Old Aug 9, 2009 | 09:11 PM
CDF302v8's Avatar
CDF302v8
Originally Posted by baldboyford
I'm not positive where the fuel filter is on a '85. On my '96 it is on the driver's side approx. inline with the front edge of the door on the inside of the frame rail. I would think your '85 would be the same or very close. Unless with a carb'd motor it may use and inline filter up in front of the carb. How long has since it has been changed? Also, have you fixed your original problem?
I fixed the idle problem...now i need to fix the warm starting problem.
Okay, i think i know where it is...what does it look like?
Nope, never been changed.
Old Aug 9, 2009 | 09:16 PM
baldboyford
Hey CDF302v8, please see my edited post, I misread your post and originally gave you the location for the fuel filter instead of the fuel pressure regulator. Sorry, I must've had a brain fart or something.
brcwelding
Feb 6, 2012 09:16 PM
ahgoo
Oct 10, 2011 09:29 AM
WMH
Sep 2, 2004 01:33 AM
bronco cam
1978 - 1996 Big Bronco
Sep 16, 2002 01:59 PM
