speedometer cable hole plug
Old Dec 1, 2008 | 12:34 PM
allen o's Avatar
allen o
Does anyone make a plug that will close off the hole for the speedometer cable, where it goes into the transmission? Not going to have a speedometer on the mud truck and need to plug off the hole. Hate to have to revert to the ole wooden plug trick..
Old Dec 1, 2008 | 02:40 PM
rclarke's Avatar
rclarke
In 1992 when speedometers started being driven from the rear end sensor many 4x2 transmissions still had speedo drive openings which were pluged with a plastic plug. A search of a wrecking yard might come up with one.
Old Dec 2, 2008 | 12:19 PM
bashby's Avatar
bashby
A freeze plug should work if yo ucan get the right size
Old Dec 2, 2008 | 12:39 PM
FordxFour's Avatar
FordxFour
Do you still have the old speedometer cable? Just cut it off and put it back in the transmission. This is what I do.
Old Dec 2, 2008 | 12:40 PM
Ford_Six's Avatar
Ford_Six
Rubber oil pan drain plug?
bradphx
Oct 12, 2016 04:07 PM
Rentaro
Feb 18, 2016 03:15 AM
Higbean
Nov 30, 2013 04:47 PM
rd_anderson20
Jul 4, 2011 02:16 PM
